Over heating on 04' Z
Old Jun 14, 2010 | 09:32 PM
defftones02's Avatar
defftones02
Arrow Over heating on 04' Z
I've had my 04’ Z for about a year. The cooling fan only used to turn on when I turned on the A/C and every once in a while.
Four days ago it started turning on almost immediately after I turn on the car.
Yesterday, the temperature gauge began creeping up, well on its way to overheating, only after 20 minutes of driving on the freeway.
Today, I changed the radiator fluid. Five minutes later the cooling fan kicked in again and stayed on. After a 20 minute drive to work at about 70mph, the temperature gauge started creeping past the half-way mark.
Could you guys confirm the following necessary steps and their oder?
1.Change the thermostat
2.Bleed the system
Anything else I might have missed?
Thanks-
Old Jun 14, 2010 | 10:10 PM
bigcheda's Avatar
bigcheda
I had the same issue, for me it was just bleeding the air valve in the back and it started working fine again (its been about 3 weeks)
read this thread, it helped me
https://my350z.com/forum/engine-and-...st-70-mph.html
Old Jun 15, 2010 | 04:52 AM
Welcome. 9 out of 10 times the problem is the thermostat. Fresh coolant will not fix a broken thermostat.
Old Jun 15, 2010 | 06:21 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Nissan had a recall on the fans.. they extended my warranty to 80k and replaced them free of charge. Call your dealer and see if you qualify.
Old Jun 15, 2010 | 06:29 AM
JCat's Avatar
JCat
You have two fans. They both should run when the air conditioner is on.
(I just had a faulty one replaced for free)
Old Jun 15, 2010 | 07:09 AM
bkaa's Avatar
bkaa
change the thermostat and bleed the system afterwards. had the same problem about a year ago.
Old Jun 15, 2010 | 08:57 AM
defftones02
Thanks everyone. Very helpful.
Chris350z03
Oct 8, 2023 07:19 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
