Fuel pump?
Old Jul 2, 2010 | 07:57 PM
vdemon311's Avatar
vdemon311
Default Fuel pump?
looking for opinions/help. My fuel pump went, So i am in search of a new one. 2004 base z with bolt ons. The options are:
1)Replace the fuel pump with a walbro 255 (100$) and modifications
2)Replace the entire fuel pump assembly and fuel pump already inside(300$) with an OEM set-up, no modifications required, pop in and go.
3) same as above , but what is known as an Airtex fuel pump. This is supposedly superior to the OEM assembly and pump (300$ as well)
I am doing the install myself, Suggestions? Comments? maybe some other options I do not know of? Also , if i purchase the full assembly, do i need to replace the fuel Level sending unit as well?
Old Jul 6, 2010 | 08:50 AM
Zazz93's Avatar
Zazz93
I hear the Walbro option is not that hard to do but since I’ve never done it (and I have reservations about the elevated p.s.i.) I can’t say go that route for a DIY’er. But there is one other option if you feel you need a higher flow option, Nismo Fuel Pump. Last I checked it was about $440 and boosted flow from 90 to 165L/h (I believe the Walbro is a 255).
Old Jul 7, 2010 | 03:13 AM
vdemon311's Avatar
vdemon311
Nismo sounds good. I will have to find out more thanks
Old Jul 7, 2010 | 04:19 AM
Synjn's Avatar
Synjn
Walbro!
Old Jul 7, 2010 | 04:34 AM
cdoxp800's Avatar
cdoxp800
Walbro.
How to install:
http://www.cj-motorsports.com/342install.htm
