My Z just quit!!!
Old Jul 13, 2010 | 11:10 AM
Liljrocket's Avatar
Liljrocket
Exclamation My Z just quit!!!
Hey guys, I was driving on the highway when my '06 350Z just quit like I had turned off the ignition with no warning. It turns over but it's like it's getting no fire to the plugs. When I turn the key to the on position the radiator fan turns on full blast. The mechanic hooked up his computer to the car and nothing is happining. He can't get in to it. I changed out the ECU and that didn't fix anything. Still the same problems. Any advice would be greatly apriciaded.
Old Jul 13, 2010 | 11:31 AM
kacz07's Avatar
kacz07
If you have a K and N filter, put your OEM back in.
Old Jul 13, 2010 | 12:50 PM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Check your fuses in the fuse block under the hood. When the engine control fuse is removed the fans will run continuously like that, sounds like it may have blown.
I should also add that the fuse is 15amp and is actually labeled Ign & ECCS cont.
Old Jul 13, 2010 | 04:36 PM
NewJoyZ's Avatar
NewJoyZ
sounds like fuel starvation.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Workshop12
Mar 23, 2020 01:45 PM
RiujinZero
Sep 25, 2015 01:19 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
FromGtoZ
Sep 20, 2015 03:41 PM
