Can someone show me where to mount the AC Condensor? (Pics provided)
Old Aug 13, 2010 | 01:37 PM
acheung456's Avatar
acheung456
Default Can someone show me where to mount the AC Condensor? (Pics provided)
I think I must be challenged or something, but I can't seem to figure out where it goes for the life of me. I already got the Spring Lock's off for the lines, but I have to install the rad/fans and am not 100% where exactly the condensor mounts, in front or behind the rad, or where it bolts into the core support.
Can someone circle or describe?
Many thanks
Old Aug 13, 2010 | 04:44 PM
winchman's Avatar
winchman
The condenser coil is mounted in front of the radiator. The parts diagrams here might help:
http://www.courtesyparts.com/350z-pa...5_751_771.html
http://www.courtesyparts.com/350z-pa...5_736_742.html
As best I can tell, it's held by rubber pieces that fit into the two recesses that appear as raised areas in your first photo. From the "Fragile" decal, go out to the round bumps that face forward, then up/back. There are probably similar features on the bottom to hold it.
Page ATC-134 of the 2007 service manual has a drawing that seems to agree with that.
Old Aug 14, 2010 | 06:23 AM
acheung456's Avatar
acheung456
Ah, I noticed it would fit in those two tabs but I couldn't see how it mounted. Thank you, I just ordered the rubber fittings from courtesy as well as some other rubber fittings I noticed I didn't have for mounting the rad as well.
Thanks again!
350Z_Al
Oct 29, 2020 07:44 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
