Major Codes being thrown CEL
Old Sep 4, 2010 | 08:02 PM
bakerac's Avatar
bakerac
Default Major Codes being thrown CEL
The car is undriveable untill I figure it out.
1446 evap canister vent valve circuit
2122 TPS sensor // switch D circuit low input
2138 TPS sensor //switch D / E voltage correlation
1229 Sensor power supply
Pending:
0550 power steering pressure sensor circuit malfucntiuon
0507 idle control system RPM higher than expected
PLEASE HELP!
Thanks guys
Adam
Old Sep 4, 2010 | 10:04 PM
winchman's Avatar
winchman
I have zero experience with this sort of thing, but 1229 looks like it might cause a lot of other things to look bad. If the sensor power supply isn't right, the sensors themselves can't put out good signals.
Old Sep 5, 2010 | 05:24 AM
2000atlanticgt's Avatar
2000atlanticgt
Download EC section of FSM, go to page 494 and follow DTC diagnostics for DTC P1229. It will have you check engine grounds, 5V signal to accel pedal, etc. to determine the source of your issue.
Edit, added link to FSM:
http://www.nicoclub.com/FSM/350Z/
Old Sep 22, 2010 | 03:21 PM
bakerac's Avatar
bakerac
Well they found whats wrong. Its a wiring short. a broken wire in harness behind the radiator. Im hoping it stays fixed, well see.
etkms
Jun 19, 2022 06:30 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
RyansZ33
Sep 15, 2015 05:54 AM
Bigsyke
Sep 11, 2015 06:19 PM
