Engine Overheating and No Cabin Heat
Old Sep 8, 2010 | 01:32 PM
binder's Avatar
binder
i would rebleed it again a couple times in the next few weeks. There is always air in there lurking and it works it's way out once you drive it.
Old Sep 8, 2010 | 02:38 PM
imp's Avatar
imp
Will do.
Thanks for all the helpful hints.. and let's hope our wheels stay 'cool'
Old Feb 19, 2011 | 10:29 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by bardabe
see if you can hear / feel compression coming out of the radiator car
-Juan
What do you mean? Should I feel pressure or air?
Old Sep 11, 2012 | 08:25 AM
RedBullRR's Avatar
RedBullRR
So if upper radiator hose is stiff, it's signs of a blown head gasket?
Old Sep 11, 2012 | 09:33 AM
terrasmak's Avatar
Nope, means it properly holding pressure.
Old Sep 11, 2012 | 10:11 AM
RedBullRR's Avatar
RedBullRR
Thank you, now if i can get some help finding a new bleeder screw that would be **** man.
Old Sep 11, 2012 | 10:51 AM
terrasmak's Avatar
pass side back of motor going into the firewall. Its on the heater hose. #3 phillips screwdriver to remove it, do not tighten it to much , it will strip.
Old Sep 11, 2012 | 11:17 AM
SHILOW's Avatar
SHILOW
Originally Posted by vthao
Grats on getting things working again. If the problem ever persists:
1. You do NOT have air in your system
2. Your thermostat is bad - it's probably stuck close which will not allow water to travel, thus causing your motor to overheat and preventing the warm water to travel, giving you the inconsistency in cabin heat.
Best of luck
Aren't the thermosthats designed to fail at stuck open? A stuck closed therm can ruin an engine very quickly. Is this an issue with our cars that I should be concerned about?
Old Sep 11, 2012 | 11:34 AM
RedBullRR's Avatar
RedBullRR
Wish it was that easy. I need an actual new one. When I went to open bleeder valve when car over heated a bit, antifreeze blew it off, loosing it in the abyss of my engine bay. I have searched thru everything I can to buy a new one, but no luck. I may have to invent something for that. Any ideas?
Old Sep 11, 2012 | 11:53 AM
terrasmak's Avatar
Call Scott at Nissan Race Shop www.nissanraceshop.com and talk to him. He should be able to get you the part you need.
Old Sep 12, 2012 | 09:10 AM
RedBullRR's Avatar
RedBullRR
Found it, and fixed WOOT WOOT
Old Sep 18, 2012 | 07:32 AM
RedBullRR's Avatar
RedBullRR
Damn car did it again. I don't get where the air is coming in from. I'm starting to wonder if i should just replace the radiator. I just saw a hint of antifreeze where the plastic is on the radiator.
Old Dec 5, 2015 | 12:56 PM
Scottygee1's Avatar
Scottygee1
I just fixed the same exact problem in my 2003 350z. Cause was the radiator cap being faulty. Got a new one put it on and boom like magic. Pretty minor part but it keeps the pressure in the coolant system. Yes there's air in the system so def. Still bleed the air out after replacing with new radiator cap, but the cap does keep pressure in the system so that coolant flows correctly. Before I found the cause of the problem, I was only dealing the symptoms. I replaced the thermostat, radiator( which was blown) and all the hoses. Only problem was that the radiator did not come with a new cap. Changed the cap out and like magic I have pressure, which in this case was the cause of air in the system (not necessarily that it needed to have the air bleed out) or "burped".
Old Jan 18, 2020 | 11:06 AM
tever's Avatar
tever
Default no cabin heat
I recently changed the thermostat in my 04 roadster I have a non spill funnel and have been bleeding the air out of the system for over 3 hrs but still not heat what else could be the problem
Old Nov 11, 2020 | 05:31 PM
phi's Avatar
phi
I solved the "overheat + no hot air in cabin".
Mine is 350z, 2005, manual, base model. I didn't drive the car for 6 months and I got the above problem.
I did so after unsuccessful diagnosis. I followed many tips but wasn't able to pinpoint the failed component, so I flushed the radiator, replaced thermostat and bled the system to see if I got lucky.
Problem still exists after many attempts bleeding it, from up the front to opening the release cap, squeezing the pipes. Last night I gave it a final trial and was ready to order & replace the radiator as the next step. Then it worked.
This was how it happened: I bled the car for 2 hours but no bubbles coming out, and still no heat in cabin. Car parked and temperature is hot (3/4 of the gauge). If I had driven for 1/2 miles, it would have hit the overheat, top of the gauge immediately. I finally gave up, took out the bleeder container, closed the hood and went to bed. This morning, I started the car and there was heat coming out from cabit. No more overheat.
I still don't know how I got lucky or the problem may come back. I measure the 2 pipes in/out of the radiator: one was hot (120F) and the other cold (60F) and I was confused. I thought they were both supposed to have the same temperature.
So that was my story. If the problem came back, I will update. Thank those who took time to post tips and how-to.
Old Sep 17, 2023 | 03:35 PM
Trent F's Avatar
Trent F
Hey everyone i am having a overheating issue with my 06 350z. Ive flushed and refilled coolant, replaced thermostat and heat sensors but im still overheating as soon as i start driving. Im good on both oil and coolant.My heater also is blowing cold air and im unsure what to do/ check next. Anything helps, thank you
Jah70
Sep 9, 2015 10:08 PM
craig12895
Oct 26, 2014 06:58 PM
carson310
Dec 4, 2013 03:14 PM
OneLovelyZee
Apr 30, 2013 06:22 AM
