Coolant Change
Old Oct 25, 2010 | 07:25 AM
GH05's Avatar
GH05
Default Coolant Change
I have an 05 base 350z , summer driver , with only 15K on the odometer. I thought it was a good idea to change the coolant because of the acidity problem that can develop. Can I just do a drain and fill? Are there any special tricks with the Z? I had a friend do a drain and fill on a different vehicle and had overheating problems due to an air pocket? Is there any special procedure for removing air pockets? Are there special coolant or additive requirements? I was going to use good old Zerex. Thanks.
Old Oct 25, 2010 | 07:36 AM
Diesel350's Avatar
Diesel350
Yea just drain and fill. It's pretty straight forward and simple procedure. Check out the DYI on this site and there is a thread on the coolant change. One thing I did that help the drain was once the coolant was finished draining turn on the car for about a minute then turn back off and you will see some additional coolant start to drain again.
Old Oct 25, 2010 | 08:19 AM
ImWeeZzel's Avatar
ImWeeZzel
look up the coolant purge nightmare thread...
Old Oct 25, 2010 | 08:27 AM
derekinthez's Avatar
derekinthez
I just drained and filled. Never had any air pocket issues.
Old Oct 25, 2010 | 01:51 PM
I recommend:
a. Drain. Fill with water.
b. Run heater full ON.
b. Drain fill with coolant.
viva la spam mentioned coolant purge. Read up.
Old Oct 27, 2010 | 01:50 PM
Bevo's Avatar
Bevo
I did drain and fill with Nissan green coolant.
No problem at all.
lapham3
Oct 7, 2022 03:15 PM
SharX59
Sep 27, 2015 09:23 AM
