PSI Blinking, Low Tire Pressure???
Old Nov 19, 2003 | 02:51 PM
SoCalKid86's Avatar
SoCalKid86
Default PSI Blinking, Low Tire Pressure???
Hey guys, my tire pressure is at about 30 PSI per wheel, give or take two pounds depending on the temperature, but one day the PSI thing started blinkin and the low pressure indicator went on. Is this normal???
PM if u could please, this an computer thing? or should i put more pressure in my tires?
Old Nov 19, 2003 | 09:43 PM
VinaZ's Avatar
VinaZ
I think it is should be 35PSI when the tires are cold or not used
Old Nov 20, 2003 | 03:49 AM
mwr's Avatar
mwr
The low pressure threshold is 28 lbs as I recall. It's covered in your manual.
Old Dec 6, 2003 | 08:29 PM
z430hp's Avatar
z430hp
can someone please tell me how to reset the low tire pressure light after I added air. Thanks.
Old Dec 6, 2003 | 08:51 PM
LBSOHK's Avatar
LBSOHK
you dont have to reset it , it will reset itself after few miles of driving
Old Dec 9, 2003 | 07:19 PM
StoneSilverTrack350z's Avatar
Any body had problems with thier indicator dying. My right (or could be left) front PSI indicator cuts in and out (cuts out, ie. it flat lines, 0 pressure), which is annoying because everytime it cuts out the damn beeper goes off.
Taking it in soon. If you have had this problem let me know.
~AJ
Old Dec 10, 2003 | 06:07 PM
350Z_Track's Avatar
350Z_Track
Does any body know if the top number goes to the left or the right tire?
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
