03 throttle body idle relearn
Old Jan 24, 2011 | 09:54 AM
dchi_t's Avatar
dchi_t
Default 03 throttle body idle relearn
I have a little problem with my throttle body, i seem to have to do the idle relearn process everytime i start the car. i was getting a P507 code (high idle), i performed the idle relearn process successfully and the idle returns to normal, however once i turn off the ignition and start the car back up, the idle goes up again and i have to do the idle relearn again! is there something screwed with the memory on the TB? the battery is good
Old Jan 26, 2011 | 06:07 AM
RedBullRR's Avatar
RedBullRR
If it's an 03 your in the wrong section, but.. Im feeling helpful so.. Have your Crank Position Sensor checked.
Old May 10, 2013 | 07:28 PM
NOLAGG's Avatar
NOLAGG
I am having this exact problem as the op what do I do in this case ? It was after I cleaned the throttle body with throttle body cleaner .... It idles around 1000 and then after relearn it idles great again until I turn the car off and restart it .
Old May 25, 2013 | 11:45 AM
NOLAGG's Avatar
NOLAGG
Any one ?
liqalu04
Jan 2, 2022 12:58 PM
