Z Wont Start: P0123, P0223, P1122, P2135
Old Jan 29, 2011 | 02:11 PM
datboyvinh's Avatar
datboyvinh
Default Z Wont Start: P0123, P0223, P1122, P2135
So a month ago i removed the plenum to have it polished. I finished it today and had it reinstalled with the motordyne spacer. Had everything plugged up and all vacuum lines secure.
When i try to start the car sounds like it starts up but doesnt start. If that makes any sense
So i plugged in a code reader and it reads 4 codes
any help or insight would be appreciated. I did decide to buy a remain throttle should i buy a APP sensor too?
Also when i was polishing the plenum i did clean the throttle when carb cleaner when it was disconnected from the car
Old Jan 29, 2011 | 02:33 PM
cdoxp800's Avatar
cdoxp800
Check that the Throttle Body is plunged in. After that preform:
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Now do the ECU Reset:
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
P0123
http://www.nissanhelp.com/diy/obd_codes/p0123.html
P0223
http://www.nissanhelp.com/diy/obd_codes/p0223.html
P1122
http://www.nissanhelp.com/diy/obd_codes/P1122.html
P2135
http://www.nissanhelp.com/diy/obd_co...35_nissan.html
Old Jan 29, 2011 | 02:39 PM
datboyvinh's Avatar
datboyvinh
thank you so much. i try this right now.
Old Jan 29, 2011 | 02:59 PM
datboyvinh's Avatar
datboyvinh
nope no luck
Old Feb 2, 2011 | 10:47 PM
datboyvinh's Avatar
datboyvinh
ok i replace the throttle all the codes went away when doing relearn.
but as i started to drive i notice idle was high, and car shakes at stop.
then after one drive P0300 and P0507 appear. after a day of driving p0507 went away.
car started fine the whole day. then i am not able to start car anymore. and code p0300 is still giving me trouble any advice? car will not start. i want to bring car to dealer cause my friend works there but i can not get it started
dutchboy350Z
Feb 15, 2022 11:07 PM
VO...
Oct 4, 2018 10:50 PM
disturbed2483
Aug 5, 2009 05:54 PM
one350zfan
Feb 24, 2007 04:49 AM
Juztin
South West
Jun 15, 2004 06:33 PM
