Weird idle?!?
Old Jan 31, 2011 | 03:05 AM
gixxer1000's Avatar
gixxer1000
Default Weird idle?!?
Hey guys hope you can help.. 2 weeks ago installed a cone filter on my 350z.. I never discounted the battery on install?? Don't know if that matters.. Well I notices this morning the z was idling very strange ?? It would goo from I'm guessing 750ish to 500ish and back?? Do I have to reset some thing?? Could it be the new filter?? If it's the filter causing this I have no issue putting it back to stock .. Thanks guys
Old Jan 31, 2011 | 04:11 AM
RandomHer0's Avatar
RandomHer0
Disconnect your battery and leave it over night.
It will re-learn idle.
Old Jan 31, 2011 | 04:49 AM
gixxer1000's Avatar
gixxer1000
Ok I will try this.. If not should I put the stock air box back on?
Old Jan 31, 2011 | 04:53 AM
RandomHer0's Avatar
RandomHer0
clean the MAF.
Old Jan 31, 2011 | 05:44 AM
PerfZ's Avatar
PerfZ
Do the pedal resets for idle air learning, etc.
Old Jan 31, 2011 | 07:07 AM
gixxer1000's Avatar
gixxer1000
Thanks guys .. I will give it a shot .. If not the old boxes goes back on
Old Feb 1, 2011 | 03:05 PM
Mint Racer's Avatar
Mint Racer
what cone filter, was it an oil filter? if so the MAF will need to be cleaned, it can cause a "fishbite" at idle, a small miss then picks back up. it may also miss at high rpm at full throttle. this is the MAF sending an irratic signal to the ECM. causing an improper AFR. other possibilities exist for this condition in the fire triangle. check you're plugs. check you're fuel.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
