Front wheel noise?
Old Nov 25, 2003 | 07:23 PM
only1's Avatar
only1
Default Front wheel noise?
Anyone know what would cause a weird wheel noise as I slow down under about 20 mph? Its not when i brake but it sounds like a noise like I can actually hear the wheel spinning, but its pretty loud.
I know...kinda vague..but any ideas?
Old Nov 26, 2003 | 07:34 AM
jelledge's Avatar
jelledge
Default Check your tires
Sounds like tire feathering / cupping. Check your front tires for abnormal wear or if you are not mechanically inclined take it to your local Bridgestone dealer...
Old Nov 27, 2003 | 07:51 PM
bhobson333's Avatar
bhobson333
This is a known problem. You should use the search feature.
Tire noise tech bulletin
Old Nov 28, 2003 | 12:29 AM
CottonWoodz's Avatar
CottonWoodz
Originally posted by droideka
The wear problem on the inside of the tire is cupping and is caused by too much toe-out. Period. Once I had my toe-out corrected way back when, I've NEVER experienced cupping ever again. Yes, I'm the one who started the "feathering" thread and mistakenly called cupping "feathering". I was mis-informed.
Feathering occurs with too much toe-in and will shread a tire in two-thousand miles depending on the severity of toe-in. Feathering helped me destroy 5 sets of tires this year due to my dealer's FAULTY alignment machine.
Justin100
Nov 25, 2021 06:26 AM
samansharif
Sep 25, 2015 12:31 PM
