3 pc. crank pulley install instructions?
Old Feb 14, 2011 | 01:05 PM
sluggoZ's Avatar
sluggoZ
Default 3 pc. crank pulley install instructions?
By using common sense and trying to avoid extra work in replacing the 3 pulleys & 2 belts.
Thanks!
The old link here that I found in "research" shows to many un-necessay steps!
Old Feb 14, 2011 | 02:14 PM
qqqqball's Avatar
qqqqball
pull fan. than radiator, undo 10mm bolt holding ac lines to frame, disconnect pressure switch on ac condensor, swing condensor out of way.
loosen alt pulley, Undo belts, use puller on crank. Line up woodruf key for new pulley, install crank pulley, replace water pump pulley, replace alt pulley.
Find correct size belts, stock one wont work
install in reverse
burp coolant
Fixxxercask
Nov 9, 2015 11:10 AM
nanotech
Oct 2, 2015 05:02 AM
