HELP...please
Old Feb 18, 2011 | 11:58 AM
makeshiftballer's Avatar
makeshiftballer
Default HELP...please
so i actually have 2 problems
first i installed a set of alpine components and ram speaker wire through the harness like the tutorial on ********* says and now my passenger window will not roll up.. i dont think there is power even getting to the switch. this problem happened after i did the drivers door(did this side first, driver window works fine) neither the passenger controls or the driver controls do anything...
second which isnt as big of a deal is that the drivers out side door handle has never worked the inside works fine. until now i would just roll the windows down with the key fob and use the inside handle..
any ideas??? the window was working fine before this.
Old Feb 18, 2011 | 01:04 PM
laser24's Avatar
laser24
is the passenger side window motor playing music? :P
Old Feb 18, 2011 | 01:27 PM
AJCaron12's Avatar
AJCaron12
Make sure the window lock isn't set on the drivers door master switch.
Old Feb 18, 2011 | 01:38 PM
bmccann101's Avatar
bmccann101
Default nICE!
I HAVE A SNEAKING SUSPICION ON HOW THIS WILL END...
Old Feb 18, 2011 | 01:48 PM
AJCaron12's Avatar
AJCaron12
Lol, I've seen it before.
Old Feb 18, 2011 | 02:00 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Feb 18, 2011 | 03:07 PM
makeshiftballer
omg i hope so lol. ill be right back
Old Feb 18, 2011 | 03:09 PM
makeshiftballer
holy **** yes thank you. i feel stupid but damn im glad that worked haha why would the driver controls not work when thats on? makes no sense
any idea about the door handle? im afraid that ones not as easy
Old Feb 18, 2011 | 05:57 PM
AJCaron12's Avatar
AJCaron12
Haha no problem dude. I'm glad you got away with the cheap easy fix. You may need an exterior door handle assembly. Take the door panel off and check it's operation. Also make sure the rod and everything is connected on it. Let us know.
Old Feb 18, 2011 | 06:00 PM
AJCaron12's Avatar
AJCaron12
Good call, ha
Old Feb 18, 2011 | 06:07 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I gotta admit, this same "problem" frustrated me before, too.
As far as the door handle, you'll probably have to take it apart to see if everything is in place. The inner handle pulls on a cable that unlatches the door, but I'm not sure of how the exterior handle is assembled.
Old Feb 19, 2011 | 03:00 PM
makeshiftballer
ok thanks ill take it apart tomorrow and check it out. thanks
grateful_350z
Aug 10, 2009 02:18 PM
