Car jerks
Old Nov 13, 2020 | 07:00 PM
timeltel's Avatar
timeltel
Regards Mathew Napoli: "is there something wrong?"
How many miles on your Z? You might check for lash in the drive train. Worn universals or wear in the
differential are suspect.
Raise your Z from the rear lift point & apply all safety precautions. With the car in neutral, as forcibly as possible rotate a rear wheel back & forth. If you suspect excessive play then check the driveshaft universals. Nissan will tell you the universals cannot be replaced, they can.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
