Manual trans rev help!
Old Mar 14, 2011 | 09:25 PM
lillong1991's Avatar
lillong1991
Default Manual trans rev help!
i have an 05 350z touring manual transmission. when i put the car in 3rd gear or higher and floor it at 2k rpms it revs up to 3k, then drops down to like 2.5k and then revs back up faster. it does it in a smooth motion. is this normal?
Old Mar 14, 2011 | 09:28 PM
Emski's Avatar
Emski
clutch slip. need replacement
Old Mar 14, 2011 | 09:30 PM
lillong1991
car has 26k miles on it...
Old Mar 14, 2011 | 09:45 PM
chrisjersey06's Avatar
chrisjersey06
There are thousands of Z's that have needed their clutches replaced much sooner than 26k miles. Some as early as 10k or less. All depends on how the car was driven, how it was broken in, type of roads the car was driven on (city/highway), etc. A friend of mine purchased an 05 Z new to learn stick on, and needed his clutch replaced within 6 months of owning. You are experiencing a clutch slip just as stated above, and the only fix is a replacement. Check out the vendor section on here for a good deal on an upgraded one that should last a bit longer than an OEM piece (as long as you are experienced at driving a manual trans).
Old Mar 15, 2011 | 12:02 AM
sportbiketed's Avatar
sportbiketed
+1
Original owner sucks at driving a manual.
Old Mar 15, 2011 | 05:36 AM
Swimminggerman's Avatar
Swimminggerman
26k is mileage, it does not reflect actual wear/abuse on components. It may be used as a guideline or general basis. There are cars with 50k that look and drive if only had 10k on them, while there are cars with 10k that drive as if they've had 150k on them.
Not to hard to burn out a clutch. i recommend replacing it as well.
Old Mar 15, 2011 | 08:12 AM
christol's Avatar
christol
And every time you floor it and make it slip, you are wearing off what little you have left.....
Old Mar 15, 2011 | 09:17 AM
lillong1991
I didn't notice this problem until today when I put new tires on the car.
Old Mar 15, 2011 | 09:58 AM
christol's Avatar
christol
Still - it really sounds like your clutch is slipping. Only way I can think of that can relate back to your tires - 1) your old tires were terrible and they slipped before the clutch (not likely) or 2) whoever put the tires on somehow pinched or restricted the slave cylinder line - not allowing slave to return fluid fast enough and slowing slave cylinder (again, not likely). Sorry but I think you're still looking at a clutch replacement.
Old Mar 15, 2011 | 08:14 PM
jc6117's Avatar
jc6117
Originally Posted by sportbiketed
+1
bought an 04 base model. Im the second owner. I asked the owner to drive the car for me when I was first taking a look at it. Have to say i've never thought I meet the most horrible manual transmission driver. All the gear switches had horrible pulls and bobbing. over revving. at one point it stalled and blamed his "3 months not driving stick".
Old Mar 16, 2011 | 12:57 PM
drivessidewayz's Avatar
drivessidewayz
^^ is bs, haha.
I agree with the clutch slip crowd btw. You can haz buy my stocker! I don't suck at driving stick >.<
Dr.Paulyy
Jul 29, 2019 07:45 AM
