Help!...engine studdering at WOT
Old Apr 10, 2011 | 04:45 PM
trefling's Avatar
trefling
Default Help!...engine studdering at WOT
Went to the track last summer, it was hot! Maybe around 105 outside.
About a half way down the track I was told a little puff of black smoke came out and from that point anytime I was driving the engine would start studdering around wide open throttle.
It does not matter is I turn the boost down to 6 psi or 16psi. Car runs great otherwise, its only at WOT where there is problems. Its also fine if it's in boost.
I replaced all the ignition coils, spark plugs and gaped them to proper clearances.
Mods:
Greddy TT
fully built engine
HKS VPro
Everything was fine before I went to the track.
Ran a scanner and the following codes came up:
P2135 (Throtal/pedal position sensor switch)
P0223
P0123
Lots of smart guys here, please help..Thank you
Old Apr 10, 2011 | 05:08 PM
trefling's Avatar
trefling
anyone?
Old Apr 10, 2011 | 05:35 PM
bluelineshooter's Avatar
bluelineshooter
Sounds terminal. Trade it in on a GT-R
Old Apr 10, 2011 | 06:02 PM
trefling's Avatar
trefling
sorry, not the answers I was looking for
Old Apr 10, 2011 | 06:13 PM
Nexx's Avatar
Nexx
does the same to me sometimes when i do a pull starting in 3rd, not all the time just every once and awhile.
Old Apr 10, 2011 | 06:17 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Default Throttle Sensor
I'm sure you already checked, but the other two codes are throttle sensor related as well.
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
Old Apr 11, 2011 | 01:54 PM
ed@aph's Avatar
ed@aph
Vendor - Former Vendor
one of my customer brought his car into my shop couple weeks ago with a p2135 and p2138 code. replaced accel pedal asem with new tps on it, works fine now after tps re-learn. didnt happen to see the other 2 codes you mentioned thou.
FromGtoZ
Sep 20, 2015 03:41 PM
pdexta
Sep 14, 2015 11:27 AM
Bigsyke
Sep 11, 2015 06:19 PM
t32gzz
Tuning
13
Mar 17, 2004 06:14 PM
richhoward
Jan 24, 2004 03:20 PM
