Random misfire... PLEASE HELP :(
Old May 10, 2011 | 10:44 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
https://my350z.com/forum/southern-ca...cal-shops.html
Old Jul 27, 2011 | 09:37 PM
jubes's Avatar
jubes
Just to update you guys, this is how the car sounds after 2 junky mechanics (one from this forum) and the stealership trying to charge me $9k for a motor.
http://youtu.be/jSwO117k7sY?hd=1
http://youtu.be/NCeL_BUQIHc?hd=1
Old Jul 28, 2011 | 07:25 AM
John1006's Avatar
John1006
If it's dumping too much fuel, have you checked your fuel pressure? And maybe the orings on the injectors got smashed when reinstalling them. Just and idea.
Old Jul 28, 2011 | 02:15 PM
jubes's Avatar
jubes
I think its still dumping lots of fuel.. the fumes are purely white..
Old Jul 28, 2011 | 02:41 PM
John1006's Avatar
John1006
Usually too rich it's black fumes, coolant white fumes, and oil bluish white fumes
Old Jul 28, 2011 | 11:32 PM
djamps's Avatar
djamps
You have a steady misfire. Unless it's mechanical, it's caused by blown coil packs, fouled plugs, \stuck injector, wiring issue, or any combination...
Does that 'knocking' sound go away when you push the clutch in? If not, you have either a serious exhaust leak or a bad case of rod knock to go with the aformentioned... my gut feeling is the engine is toast.
Good luck... wish you took it to a reputable VQ mechanic (NOT the dealer under any circumstances) instead of wasting 2k+ and taking ill advice to drive it with a steady misfire...
Old Jul 29, 2011 | 08:11 AM
jubes's Avatar
jubes
The fumes are white, but it smells a whole lot like fuel..
I have new plugs, the first mechanic changed both valve covers and 2 coil packs, the 2nd mechanic changed one injector, gasket...
The knocking does go away when I press the clutch.
Yeah, I learned my lesson big time..
Old Jul 29, 2011 | 08:41 AM
mw9's Avatar
mw9
I am having similar problems, but it finally throw a code telling me its cylinder 4, keep us updated, maybe I will try coilpack and injector
Old Jul 31, 2011 | 01:00 AM
jubes's Avatar
jubes
Mine started with cylinder 6, then went to cyl. 1.. Now it says cyl. 2... Yeah it sucks
leonchus
Sep 29, 2015 07:04 AM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
AbyteZero
Sep 22, 2015 09:17 AM
louisbs
Sep 29, 2003 11:20 AM
