Startup Issues
So there's a couple things that i've noticed on my 03 with 112k lately
first issue
when i start the car after driving it for a bit the RPMs will dip down incredibly low(almost to the point of stalling) or will stall....this started around 95-100k, now it does it almost every time. the only way around it is to give it a little gas to keep the rpms up.
could it be the MAF sensor or the battery causing this problem?
the only reason i bring up the battery is because it has the factory battery still, the voltage looks normal, 14v and doesnt jump around
but with the MAF, the issue started around the time i cleaned my K&N, i had an emergency and had to use my vehicle before i could wait the full 30 minutes to let the oil sink in all the way on the filter(i waited 20 minutes)
second issue
when i auto up my passenger window when it's warm out it will go all the way up, and then back down 1/4 the way, it does it from both window controls, i'm kind of clueless on this one
third issue
my gas gauge is totally jacked, when i fill it up it comes to half way now and bounced between empty and 1/8th tank by the time i hit 180 miles. i'm at the point where i just reset the trip after every fill up and run about 350 miles inbetween
thanks in advance for any help
first issue
second issue
third issue
Spring for a new battery. It's past time, and an unexpected failure is terribly inconvenient. It may or may not solve some of the other problems, but do that first.
From what I've read, the gas gauge is not very reliable. Your approach is pretty easy, and it works. I couldn't justify spending any money trying to fix the gauge on an '03.
There's a procedure for getting the window motor to stop in the correct place. Search for "window learn" or something like that.
with re to the gas gauge problem, i heard that leaving the car idling during fill up can cause this problem to occur otherwise it might be a gauge wiring or fuel sensor issue
first issue
second issue
third issue
first issue
second issue
third issue
