Rattling Gear Shifter - Any help/advice appreciated
Old May 1, 2011 | 07:45 AM
RS8055's Avatar
RS8055
Default Rattling Gear Shifter - Any help/advice appreciated
Hi Guys,
When I am in motion driving my Z, there is now a metal sounding rattle noise coming from what appears to be the shifter. Wondering if anyone knew any way to tighten it at all or to fix it?
Any help or advice will be greatly appreciated.
Many Thanks
Old May 1, 2011 | 07:46 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
stock shifter, or short shifter installed? stock shift **** or aftermarket?
there are bolts that hold down a metal frame under the plastic console (4 of them, 10mm heads). Check those. Also, there is a single nut/bolt that connects the lever to the shifter. May want to check that too.
Old May 1, 2011 | 08:08 AM
RS8055's Avatar
RS8055
Yeah, it's a stock shifter with a stock **** on it. How is it I get under the plastic console? (No easy access points that I can see)
Old May 2, 2011 | 11:21 AM
green_bread's Avatar
green_bread
You just grab the "ring" that goes around the shifter and pop it up. Its not bolted or screwed down. It should pop out pretty easily.
sherm
Apr 11, 2020 05:21 PM
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
