Torque specs for spark plugs?
Old May 4, 2011 | 03:18 PM
350Z400rwhp's Avatar
350Z400rwhp
Default Torque specs for spark plugs?
I haven't been able to find any torque specs on here for the spark plugs. I am changing them now and noticed that 3 out of 6 of my plugs were very loose pretty much hand tight if that while I was removing them. I did a general search online and have found torque specs on aluminum heads from about 13ft lbs to 29ft lbs.
Old May 4, 2011 | 03:32 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
15-21 ft-lb (180-252 in-lb).
I just did my, and torqued them down to 20 ft-lb. It is a good idea to go back after a few heat cycles and re-torque them.
Old May 4, 2011 | 03:33 PM
midz350's Avatar
midz350
From the O6 FSM:
Spark plug: : 24.5 N·m (2.5 kg-m, 18 ft-lb)
Old May 4, 2011 | 03:35 PM
350Z400rwhp
Hey Sasha are you able to get to the plugs without removing the intake manifold? I just removed everything as it seemed easier but to just re-torque them that seems like a bit of work. Those coil packs are hard to get out.
Old May 4, 2011 | 05:00 PM
FranK0Amerika's Avatar
FranK0Amerika
I just did mine. At the risk of being yelled at, is it necessary to torque them? I just tightened them as much as possible with my socket wrench and it seems to run just fine.
Old May 4, 2011 | 05:37 PM
Boosted Performance
Yes it is possible, I have done it for this reason (re-torque). It is a bit of a PITA but can be done. You just have to unclip the coil from the harness, and it comes out easily. A 1/4" drive will get to all the 10mm bolt holding things down, to allow good access to the plug. I also use spark plug anti-seize, you can never be to careful with aluminium.
This is a very good way to get rid of a lot of money. If you strip the aluminium head, you are up the creek. The heads will have to come off for proper repair/replacement. There is a reason they invented a torque wrench. You don’t always have to use it (eg: suspension components), but when dealing with aluminium it is almost a must.
Old May 4, 2011 | 06:01 PM
350Z400rwhp
Thanks Sasha! One last question, if these plugs were loose I assume I lost some compression, if I had it tuned with the three plugs loose now that I tightened them will this throw my tune off? I plan on keeping a close eye on my a/f gauge.....
Old May 4, 2011 | 06:06 PM
failsafe306's Avatar
failsafe306
I've never really used a tq wrench on plugs, I just turn them down hand by hand until they hit bottom, then go another 1/4 to 1/2 turn. You'll feel the crush washer give a bit, then you know you're good to go. Never had one come loose on me and surely have never stripped out a head. Remember to use anti-seize compound on the plug threads.
Old May 4, 2011 | 06:21 PM
Boosted Performance
I don't think you should worry about your tune that much, but do check your a/f just to make sure.
I have no problem doing this either because I have a feel for it. People that have never done it though, can easily over tighten them and make a mess. Aluminium will give you plenty of warning/feel back, if you know what to look/feel for.
Old May 4, 2011 | 07:54 PM
350Z400rwhp
I used the anti-seize and torqued them to 20ft lbs all the way around. I didn't put them nearly that tight when I installed them the first time. Even 20ft lbs seems like I was going to tear the threads out lol (but that's just me being paranoid, knowing what is at stake). I'll re-torque them in a couple of weeks after some heat cycles to make sure they are still to spec. Thanks for all the advice!
Old Feb 7, 2014 | 08:44 AM
slvrman's Avatar
slvrman
Default Rev-up
What's up guys, I have been searching for almost 2 hours a cannot seem to find a thread on the torque specs to change the spark plugs on my REV-UP , if anyone knows the many INCH POUNDS because that is the only torque wrench I own as of now please help me out I cannot find it anywhere. If it is on here somewhere I must have missed it I scrolled the rough multiple pages of threads. Again please help need info ASAP
CALLING ALL ENGINE GURUS!!
Thanks in advanced guys.
Old Feb 7, 2014 | 09:17 AM
jhc's Avatar
jhc
General & Tech Moderator
Here you go. Search "Spark plug torque"
https://my350z.com/forum/forced-indu...ark-plugs.html
Old Feb 7, 2014 | 12:42 PM
graffkid732's Avatar
graffkid732
If it's 18ft lb. How many inches in 1 foot? 12 inches.
18ft * 12in = 216
So you would want to do 216in lbs to equal 18ft lbs.
Old Feb 7, 2014 | 08:00 PM
soc_monki's Avatar
soc_monki
ive always just hand tightened, then done about a 1/2 turn with a ratchet. starting the plug by hand is a good way to make sure you dont cross thread, and the specs on the plug boxes say about a 1/2 turn more is all you need. never had a problem out of my Altima, and I assume my Z will be the same way when i change her plugs.
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
