Help!! WINDOW MOTOR OR SWITCH????
Z started acting up
The driver side window wont go up, then i slam the door a couple of times and then it press the button and it rolls up...
with the window fully up, i close the door and the window tries to go up to form air seal like 10 times...
Is it the switch or the motor ,, stressed and super inconvenienced.
Generally speaking, the window motor seems to be more problematic than the actual switch itself so I would look into replacing the motor (verify this with a mechanically savvy individual though). Unfortunately, window motors aren't cheap (one of the least expensive OEM replacement parts that I found was $190 http://www.nissanpartszone.com/parts...731-cd00a.html) and the labor can be a P.I.T.A. but sometimes you just have to bite the bullet and plunk down your hard-stolen cash in order to rectify irksome issues. My window goes up and down as slow as molasses in January so I'm looking into replacing the motor too. Let me know if you know of any good write-ups if you're going to do the job yourself!
