help my car takes time to start
hi there
am from Saudi Arabia and nobody there know how to fix the 350z
i have problem the car takes 5 to 10 seconds to start see the video
http://youtu.be/ijI8Mdd1iSk
the problem begins when i change the old motor then the car be so slow
even a 1.5 Subaru is faster then the 350z i took it to car shop he told me
when they
installed the new engine they connect the left cam sensor with the right one
and so the right one he fix this problem but the car now takes time to start
he told the all the sensors are ok but the problem is from bcm or bcu
it needs to restarted cus the car sensors is ok
so tell me what i do now and how i can restart the bcm or bcu
or is there any body knows the problem with my car
03 350z 6speed
when they
03 350z 6speed
Run an OBDII test and see what code comes up. To be honest because the sensor seem ok doesn't mean it is. If the connector is not sensing the right reading from the sensor then it will go into "limp mode" causing the car to be tremendously limited.
From the video it looks like Cam sensor 1 bank 1 (passenger side) because when the symptoms matches which that sensor going out. Im not speaking 100% on this but FROM WHAT I'VE SEEN that usually is the sensor that is bad. Just run a OBDII to be sure.
i had run the test
ok you say its cam sensors i had change them with my old ones and still the same problem
Hey Abdulrhman,
Check your battery, are you getting enough volt?
Check your spark plugs, are they new?
Check the crank sensor, make sure its installed correctly, check the wiring.
Also check your flywheel, make sure there are no damage to the flywheel teeth.
my battery is ok its giving me 14v
my spark plugs are 3 months old do i need to change them
where is the crank sensor could you show a pic
i will check the flywheel
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
