P0031/P0037 Troubleshoot?
Old Jul 14, 2011 | 12:52 PM
Tischler's Avatar
Tischler
Question P0031/P0037 Troubleshoot?
My 2003 350Z is giving codes for P0031/P0037. Which are heater control circuit low for bank 1, sensor 1 and sensor 2, respectively.
I recently went in the shop because my car was stalling out at idle. Turned out I needed a new MAF sensor and a new TB. After replacing those, the mechanic couldn't set the idle, even through the ECU. It was sitting around 1200. I was getting a P0507 code, for idle control system. So I recommended an ECU replacement based on what I saw online. That fixed the high idle problem, but now I have these 2 new codes.
Any ideas??
Old Jul 18, 2011 | 07:11 PM
Tischler's Avatar
Tischler
Update: Car is in the shop now. The tech thinks that the Seafoam I used could have damaged the exhaust O2 sensors on Bank 1... I'm only getting like 17mpg, he said that is normal for a malfunctioning O2 sensor. Also, at 90K it's not a bad idea to replace your primary O2 sensors, his words...
I will post an update with the final resolution when I get her back.
Old Jul 19, 2011 | 02:11 PM
Tischler's Avatar
Tischler
Update 2: Turns out it was a faulty ECU. Used ECU for $300, and programing/install $200...
Check engine light free and running like a champ. . Thank you ZFever
Dave 90TT
South West
Jun 9, 2008 03:35 PM
nismospec
May 6, 2008 04:17 PM
SlamMan
Apr 21, 2004 08:31 AM
