06 350z track makes crackling noise on slow take off
Old Aug 23, 2011 | 11:56 PM
erik_350z_track's Avatar
erik_350z_track
Exclamation 06 350z track makes crackling noise on slow take off
Whats up guys. Ive had my 350z for about 4 months now. Im having a noise issue. The car makes a crackling noise that seems to be coming from the wheel area.. Now is this normal. It makes noise as soon a i take off from park, or put it in revers.
Issue #2
clutch peddle stays half way down sometimes.
I have to pull it back up and pump it a couple times for it to work.
Old Aug 24, 2011 | 01:05 AM
miLes.'s Avatar
miLes.
I have the same problem with the crankling noise and the clutch pedal.
I'm pretty sure the noise is coming from the axle. Which I've heard that is fixable by taking out the axle and putting anti-seize grease on the end that goes into the hub and turning it 180*.
The clutch problem, I'm not so sure about. I drift my Z and notice that it gets that way after i push the car. So basically gets that way when the clutch is heated up. Tried bleeding it... still does it. Thinking about trying DOT4, but I just don't kno if the clutch system can take DOT4.
Hope this helps & if incorrect, plz correct me.
-miLes.
Old Aug 24, 2011 | 03:11 AM
DavesZ#3's Avatar
DavesZ#3
1) https://my350z.com/forum/engine-driv...rear-axle.html
2) Search out the Slave Cylinder Recall.
Old Aug 24, 2011 | 09:45 AM
miLes.'s Avatar
miLes.
concerning the slave cylinder, would it matter if my Z is an 05? or is the recal specifically for the 07 model?
etkms
Jun 19, 2022 06:30 PM
