coolant level
Old Sep 3, 2011 | 11:13 PM
JDMStanced's Avatar
JDMStanced
Default coolant level
Is coolant not suppose to decrease over time?
Not too long ago (maybe 3~4000miles ago?), the coolant level was near LOW mark. I filled it up to MAX.
Today, i checked the level again and the coolant is at LOW mark again.
I never changed the coolant before. MAYBE the coolant was changed when i bought the car (about 10000 miles ago).
This exact thing happened to my brother's g35. But his coolant was changed about 10000miles ago by me.
now im wondering if i should change the coolant, or keep adding coolant.
Old Sep 4, 2011 | 04:31 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
coolant gets filled at the radiator not at the overflow - that's why it's called an overflow tank
follow the factory service manual for the filling/bleeding procedures
Old Sep 4, 2011 | 04:45 AM
Its a closed system. THere is no place for the coolant to go.
Old Sep 4, 2011 | 06:47 AM
winchman's Avatar
winchman
It's not really closed. There's a small hose from the cooling system to the bottom of the overflow tank. You can see the hose near the radiator cap.
If there's any air in the system, it'll expand when the engine get hot, and that'll force some coolant into the overflow tank. It will be pulled back into the system as it's cooling.
If things are working like they should, there will be very little air in the system. It'll eventually collect at the high spot under the radiator cap, and go into the overflow tank. It'll be replaced with coolant when the engine cools.
As long as the cooling system is working OK and there are no other symptoms (white smoke, obvious leaks, etc), I wouldn't be concerned. Just check it regularly, and keep adding coolant as needed. It really doesn't take much coolant to go from min to max on the reservoir.
Old Sep 4, 2011 | 09:55 AM
JDMStanced's Avatar
JDMStanced
Other than horrible stinky exhaust smell from my bro's car, everything works like they should be.
This time i'll add coolant through the rad neck and see what happens. thanks
Chris350z03
Oct 8, 2023 07:19 PM
sales@czp
Sep 23, 2019 03:30 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
SharX59
Sep 27, 2015 09:23 AM
smithmt3
Sep 11, 2015 08:25 PM
