DOT 3 or DOT 4?
Old Sep 13, 2011 | 10:15 AM
huanandonly's Avatar
huanandonly
Default DOT 3 or DOT 4?
I'm planning to bleed out the clutch line and replace the fluid.. and I noticed on the forum here that some people will replace it with DOT 4 fluid, but in the service manual it recommends an equivalent DOT 3 .... so which one should I use?... what's the difference between these fluids? (other than the temperature rating) Any info/ insight would be great. thanks!
Old Sep 13, 2011 | 02:12 PM
DavesZ#3's Avatar
DavesZ#3
Only difference is formulation. A lot of people feel DOT3 and DOT4 are the same and can be mixed, readily switched between,etc. Others feel that once you use DOT 3, you stick with it, i.e. you should replace with what the system already has in it.
for a street car, the minor differences are negligible so you might as well stick with a good DOT 3. Just get a reputable name brand and you should be good to go.
Old Sep 13, 2011 | 02:48 PM
huanandonly
Thanks for the reply, Dave... DOT 3 it is.
Old Sep 13, 2011 | 03:06 PM
RMichael's Avatar
RMichael
Lock this Dave. perfect advice.
Old Sep 14, 2011 | 11:54 AM
huanandonly
Hi Dave, ... one other question: would this also be a suitable replacement??? --- Gunk's Clutch Fluid, for manual shift vehicles (please see pic)
350trackz
Nov 6, 2003 12:49 PM
missybuto
Mar 14, 2003 09:48 AM
350zvin
Feb 22, 2003 10:11 AM
RP-350Z
Cleaning & Detailing
Feb 3, 2003 06:57 AM
Slexis200
Oct 5, 2002 08:01 PM
