Borla Exhaust
Old Sep 14, 2011 | 03:35 PM
billium's Avatar
billium
Default Borla Exhaust
Hello,
I just installed the Borla 350Z '03-08 3.5L V6 AT/MT RWD 2DR exhaust on my 06 350z and it keeps throwing a check engine light. Went back to the shop and they checked the code and it had to do with my front bank o2 sensor. They reset the code and the light went off. they told me it was a learning cpu and it would take a few miles to register it. The light came back on, on the drive home. leaving me to believe they may be crazy. Any thoughts, tricks, best practices???
Old Sep 14, 2011 | 03:54 PM
Pengu's Avatar
Pengu
Check all the bolts and make sure everything is properly connected including the gaskets. I actually had a bolt fall off that connected my test pipes even though I used my impact gun. Although I get the error code once a week for my test pipes so check around there...
I think that's the same error code at least. What's the exact code?
Old Sep 14, 2011 | 04:05 PM
billium's Avatar
billium
I'm not sure of exact code, I will try to find out.
Old Sep 14, 2011 | 05:43 PM
Classy's Avatar
Classy
There are 2 connections to the rear o2 sensors on the bottom of the transmission, I would check those, I had this exhaust on my g35 and man did it sound awesome! Enjoy it!
Old Sep 14, 2011 | 05:47 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
an exhaust alone will not cause an 02 related CEL
if you've got test pipes, those can cause it
if you've got high flow cats, those can cause it
if you've got a bad 02 sensor, that can be the cause
Old Sep 14, 2011 | 06:46 PM
Beast101's Avatar
Beast101
Default I see
I also had the same problem, as soon as I drove my Z out the shop and gunned it, it threw the code. Sometimes it turns itself off sometimes it doesnt. It wasn't until I recently I went to the stealership and now it doesnt come on anymore. They mentioned something about the o2 being removed during the install.
Old Sep 17, 2011 | 07:22 AM
Itzcashew's Avatar
Itzcashew
When you say front are you referring to the upstream or downstream sensor?
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
