Help!! Orange light with exclamation mark
Old Sep 21, 2011 | 05:57 PM
RMichael's Avatar
RMichael
I quit.
Clearly.
You hung in there though.
Old Sep 21, 2011 | 06:02 PM
Obey_Z's Avatar
Obey_Z
Yes! That's exactly it! Man screw these guys talking ****, they just don't know as well as you do. I really appreciate it! ... So I need to buy a new battery correct?
Old Sep 21, 2011 | 06:07 PM
DavesZ#3's Avatar
DavesZ#3
No, you need a new sensor. They are sealed units. There's nothing to replace in them. Plus, you have the problem of figuring out which one is out.
Next time the light comes on, look on the triple meter (computer display) and find the tire pressure readings. One (or more) will read "--" meaning that it's not getting a pressure from that sensor. Don't forget that there are two screens for pressure, use the bottom switch to toggle between Front and Rear. The top number should be the passenger side pressure, the bottom should be driver side.
Take it to your dealer and get them to replace the sensor and re-program the new one to the car.
They're not talking **** to you. They were trying to tell you that you have a bad sensor. It doesn't matter than it's a battery problem or dead sensor.
Obey_Z's Avatar
Obey_Z
Wait my mistake, I need a new sensor. What sensor is it? Do you know?
Old Sep 21, 2011 | 06:20 PM
RMichael's Avatar
RMichael
Actually it will come on in exactly 31 miles if it's bad or they aren't there.
Old Sep 21, 2011 | 06:21 PM
Obey_Z's Avatar
Obey_Z
Okay I get it now. Thanks again!
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ I hope you realize he, RMichael, was being sarcastic....
Nobody's talking ****, although I agree that Dave is an expert on various topics, including this one. I told you what the source of your problem was already; you just failed/neglected to read what was posted. In fact, it was the 1st reply to your thread, not to mention you could've answered your own question by taking a few minutes to research instead of spending those minutes to create this thread then incessantly repeat that your tire pressure is fine when it was said multiple times that tire pressure isn't the only cause.
Logically speaking, there's no way any of us would know which sensor has gone bad based on your description of "the light is on," but I digress. Again with the not reading...
FYI, you should be able to see in your little computer (left gauge of the 3 gauges above the cubby) which wheel with the bad TPMS or low tire pressure is tripping the light.
edit - you can see it on the older models, 03-06
Worst case scenario, you take it to the dealer or a tire shop and have them use a tool to let you know which TPMS is faulty (this still only works if the light has been tripped, which is an indication of a bad TPMS, because if the light wasn't on then the TPMS is supposedly working fine).
Old Sep 21, 2011 | 06:26 PM
Itzcashew's Avatar
Itzcashew
The factory provided black tape fell off. Got pick up another strip and place it over the light. Then there is no light looking at you. =D
Old Sep 21, 2011 | 06:31 PM
Obey_Z's Avatar
Obey_Z
Yes you have a point. Sorry guys I barely purchased this car a few months ago. Once again I do apologize
Old Sep 21, 2011 | 06:37 PM
RMichael's Avatar
RMichael
No my bad. I've had a few beers after work and people have been dealing with this since 2003.
Old Sep 21, 2011 | 06:48 PM
Obey_Z's Avatar
Obey_Z
Well back to the light just to be clear.
It does turn on after I've driven 25-30 miles.
It turns off once I turn off the car, drive 30 miles or so. Comes back on.
I start the car, no light on..
Old Sep 21, 2011 | 06:54 PM
3hree5ive0ero
Retired Admin
O...M...G...
If you're not going to read, just stop posting altogether, please. Much like your other questions you keep asking despite the fact that they have already been addressed, Dave already answered your question.
Originally Posted by DavesZ#3
You have a sensor with a weak and dying battery. The sensors only turn on when the car speed gets over 20 mph. That starts draining the battery down until the point where it stops transmitting. Once that happens, the CPU loses the signal and the warning light comes on. Initially, you may have to drive around for 30, 45, 60 minutes or more. Eventually the time before it fails will get shorter and shorter, maybe 10-15 minutes. If you park the car for a short time, you can drive it and the light won't come on again until the battery power drops.
Trust me on this one. I just changed a sensor for this very reason. They are designed with a battery life of about 7 years. Your 05 is probably on it 6th or 7th year of use.
BTW - note that nowhere in that explanation did I mention correct tire pressure. It has nothing to do with the problem.
^ You can replace "park the car" with "shut off the car" and it'll still apply. You can also replace "minutes" with "miles" and it'll still apply.
Old Sep 21, 2011 | 11:24 PM
Itzcashew's Avatar
Itzcashew
Just wait until you get Test Pipes. Oh joy that would be....
Old Sep 22, 2011 | 12:20 AM
AngelsVQ's Avatar
AngelsVQ
i cant believe this has dragged to 2 pages.in to see if question is asked again
Old Sep 22, 2011 | 05:29 AM
JERZ350's Avatar
JERZ350
Not sure if they work on all years but, just incase:
https://my350z.com/forum/wheels-tire...sors-tpms.html
Old Sep 22, 2011 | 10:47 AM
jerseystyle's Avatar
jerseystyle
Probably the funniest thread I've seen in a long time.
Old Sep 22, 2011 | 10:55 AM
PikesPeakZ's Avatar
PikesPeakZ
Hey guys I too am seeing this exclamation point. So I have to change my tire pressure right? Do you think the TPMS fluid is low?
Old Sep 22, 2011 | 12:19 PM
  #38
RMichael's Avatar
RMichael
Originally Posted by AngelsVQ
i cant believe this has dragged to 2 pages. in to see if question is asked again
User CP, Edit Options, Show 50 posts per page.
fixd...Now it's only gone on for half a page.
Old Sep 22, 2011 | 12:31 PM
  #39
Junkster's Avatar
Junkster
My light is always on after my RPF1's do i need a new car battery?
Old Sep 22, 2011 | 03:24 PM
  #40
RMichael's Avatar
RMichael
I bet they're Enkei replicas. No, you need more blinker fluid.
ew, that's going back a bit.
