03 tapping issue??
Old Nov 7, 2011 | 06:37 AM
350ZToeRing's Avatar
350ZToeRing
Default 03 tapping issue??
I have an 03 Z with 140K miles on it.
The car has performed flawlessly until last night. I went out to the driveway to pull it into the garage and when I cranked it, I got a loud clack-clack-clack-clack sound that (over a 25 second span) softened into steady tap. The Tap does increase with revs.
I immediately checked the oil as I assumed it was some type of knock. Car is fine on oil, even added a half quart to make sure I was within the marks.
This morning I crank to go to work and its the same thing. This time a check engine light comes on. P0304 misfire to cylinder 4. Car drove fine to work and I couldn't even hear the tap anymore. I recranked it (car warm) and no clack or tap.
I want to think that this is more than simply a misfire cylinder because of the terrible clack-clack-clack sound.
My next step is to swap a coil to cylinder 4 to see if the code changes to another cylinder. If it doesn't I guess I will change the plug.
Does anyone have any other thoughts? I have read things such as timing chain and valve tapping/needing adjustment? And if it was the valves needing adjustment, I have read people saying both that you can't adjust our valves and others say you can?
HELP PLEASE??
Old Nov 7, 2011 | 01:19 PM
350ZToeRing
TTT any thoughts guys?
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
