My Head Lights and Turn Signals Stopped Working
Old Nov 28, 2011 | 12:12 PM
kingcool's Avatar
kingcool
Default My Head Lights and Turn Signals Stopped Working
I was driving home and the headlights and the turn signals stopped working. I do have a driver side high beam that works...but thats all I checked all the fuses and they are all fine, even the ones in the IPDM. 2003 Z base mod.
Old Nov 28, 2011 | 01:23 PM
bmccann101's Avatar
bmccann101
if the entire chunk of plastic died, check the connector to the main headlight harness. Pull tire, fenderwell plastic etc. Good luck.
by ipdm you mean the fuses behind the battery? Dunno.. relay perhaps.
Old Nov 28, 2011 | 04:41 PM
albinobob's Avatar
albinobob
The headlights and the turn signals are pretty isolated from each other as far as the schematics goes. Turn signals are controlled through the BCM and headlight are controlled through the IPDM. So it’s most likely a connector or wire close to the headlight housing. I’d start with checking the grounds at the headlight connector.
Old Nov 28, 2011 | 08:28 PM
JDMStanced's Avatar
JDMStanced
ALl the fuses are good on mine too, but my rear right signal doesn't work.
how do i go about checking the grounds and connectors?
Old Nov 29, 2011 | 06:26 AM
kingcool's Avatar
kingcool
I was wrong...the turn signals work, I just didn't see them until last night. I'm thinking that all the head light bulbs went. Its an 03 so they are really old. Will change them today.
Thanks to everyone for the help.
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
Shane86
Sep 17, 2015 05:33 PM
Daniel_dh
Sep 7, 2015 12:56 PM
