Throttle body removal?
Old Dec 5, 2011 | 02:25 PM
mcarther101's Avatar
mcarther101
Default Throttle body removal?
How can I remove my throttle body? It's just the 4 hex bolts connecting it to the upper plenum right? My 3/8 drive hex socket can't get to the bolts at a good angle, and they seem to be really torqued down.
I am trying to uninstall it so I can get to my camshaft position sensor that needs replacing.
Old Dec 5, 2011 | 02:31 PM
taywan's Avatar
taywan
you'll get it, make sure you unhook your battery before or your idle will be fkd up
Old Dec 5, 2011 | 03:01 PM
mcarther101
Is it a 5mm hex or 5.5mm maybe? Would a 1/4 drive fit better perhaps... agh may have to buy a 1/4 drive set.
Old Dec 5, 2011 | 03:07 PM
bikinilust's Avatar
bikinilust
UNHOOK THE BATTERY!
Then If need be, use an allen key and a set of pliers (Pliers used to rotate the allen key from its little leg)
Old Dec 5, 2011 | 03:10 PM
Neimad's Avatar
Neimad
You can pull the upper manifold with the throttle still attached. And you can change the sensor without pulling the manifold.
Old Dec 5, 2011 | 03:16 PM
scotts300's Avatar
scotts300
You have to unclip the TPS as well. I had to remove my intake tube as well.
Old Dec 27, 2011 | 02:58 PM
mcarther101
Okay there is no way to remove those bolts without taking off the plenum I guess. They are 5mm alright, but dammit if they aren't torqued down with some Loctite. I broke loose the top pair, but there's no way to get enough leverage for the bottom two without removing the upper plenum.
Will removing my upper plenum screw up my 5/16 motordyne plenum spacer? Will I need a new plenum gasket for the spacer?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
