Oil Leak [Pics Included]
Old Jan 2, 2012 | 11:54 AM
Infini7y's Avatar
Infini7y
Default Oil Leak [Pics Included]
Hello everyone,
I have been noticing for a while small oil spots whenever i parked in my garage and at work.I never payed much attention to it thinking it was just very minor. I change my oil yesterday and notice that I only had about 2 quarts of oil in my motor! I took some pictures here to try and see if you guys could help me determine the location of the possible leak and what I could do it fix. I took as many pics as I could. After this post I am going to go back under and clean up all the dirty deposits and see if I can get some even clearer pictures later to determine. Pics are below.
***Updated with Video***
http://www.youtube.com/watch?v=LsSm7b_dBFA
Old Jan 2, 2012 | 12:16 PM
hyuk28719's Avatar
hyuk28719
It's really hard to tell when everywhere is oily.
If I were you, I would jack up the car, clean ALL the oils with rag, and start the car. That way you can clearly see where the leak comes from.
Old Jan 2, 2012 | 12:26 PM
Infini7y's Avatar
Infini7y
I just recorded some video and from it you can actually see the oil leaking. Any idea where that oil is coming from. I am going to the garage to clean the oil up now so we can see more clearly.
Old Jan 2, 2012 | 12:35 PM
hyuk28719's Avatar
hyuk28719
It seems probable that the leak comes from oil filter assembly. Although I have seen oil leak from valve cover gasket and oil pan, this is new to me as well. Maybe someone more knowledgeable can chime on this.
milez921_03's Avatar
milez921_03
Oil galley plug? I had the same issue when I had my engine rebuilt they crushed the washer and created a leak that eventually a big issue.
Old Jan 2, 2012 | 03:56 PM
Replace o-ring #4 between the oil cooler and oil pan upper.
Also appears that the pan is jacked up. You can see where someone attempted to seal a bolt with RTV. I believe the pan has no gasket.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
