Searched for Days...Werid problem New z owner.
Old Feb 15, 2012 | 05:13 PM
IllicitDrift's Avatar
IllicitDrift
Default Searched for Days...Werid problem New z owner.
I juss purchased a 2004 350z base and i have a few problems i cant figure out. When i open then shut my passenger side door the windows goes down by its self, When i turn on the right blinker the rear hazards come on but the front works fine, also i cant seem to program the key fob. I get to the part where your supposed to press any button once in the sequence but nouting happens.
Any help would be awsome i am a new owner and this is my first car note.
Thnax Matt.
Old Feb 15, 2012 | 05:20 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Passenger window probably needs the "reset" procedure:
Key FOB program DIY:
https://my350z.com/forum/body-interi...ogramming.html
I got nothing on the turn signal/hazard issue but it makes me laugh imagining it
Old Feb 15, 2012 | 05:26 PM
IllicitDrift
Thanks for the reply. I have tried to key fob program sequence about 20 times. It gets to where the hazards blink the first time then nouthing else.
Yes lol its quite a sight for who ever is behind me when i put on my right blinker and my rear hazards come on. But seriously its a problem thats pissing me off lol.
I will have to try the window reset this weekend when i get a day off.
Old Feb 15, 2012 | 05:35 PM
IllicitDrift
Im thinking that the bcm may be at fault for the key fob and rear turnsignal/hazard light issues jus not sure how or what to check.
Old Feb 15, 2012 | 06:30 PM
Waiz's Avatar
Waiz
Moved
Old Feb 16, 2012 | 11:53 AM
IllicitDrift
Bump anybody?
Old Feb 16, 2012 | 01:38 PM
KornerCarver's Avatar
KornerCarver
Did you buy the Z from a dealer or private party? If from a dealer you might have some kind of warranty. If that is the case, I would take the car back ASAP and ask them to fix it. If you bought it from a private party, you are probably out of luck. I suspect your problem may be the Body Control Module and that is a fairly expensive fix.
Old Feb 16, 2012 | 04:15 PM
IllicitDrift
it was a private party and it has 114k miles on it.i jus really dnt wana take it to a dealer. Was hopin i could fix myself.
Old Feb 18, 2012 | 11:58 AM
IllicitDrift
Well so far i figured out the key fob is bad so i will start with that. Tomrrow guna try the window reset but im stumped on the tailight issue.
Old Mar 4, 2012 | 05:25 PM
chris28456's Avatar
chris28456
so is everything working properly now?
p.s. a new key fob on amazon $15 comes with programming instructions..just make sure it has a fcc id: kbrastu15
Old Mar 4, 2012 | 05:52 PM
IllicitDrift
everythang is workin now except passenger side window still drops all the way down when you open the passenger side door.
Uriyo_
Sep 8, 2021 08:46 AM
