2008 TPS issue??
Old Feb 19, 2012 | 09:23 PM
JS22's Avatar
JS22
Default 2008 TPS issue??
the tire pressure light is on constantly in my 08, after checking all 4 with 3 diff gauges. I have a question, maybe dumb ?
If my rear tire size has changed, even on stock rims (ie. 255s vs stock 245s)
will this increase in internal volume affect the reading of the TPS, causing the D@mn light to be on all dang day?
Also, I was told that some larger tire shops could "recalabrate" this.
Any truth to this?
Any help?
Old Feb 20, 2012 | 03:09 AM
DavesZ#3's Avatar
DavesZ#3
Did you read the Top 100 Questions thread and see this post...
https://my350z.com/forum/showthread....9&postcount=44
One or more of your sensors is dead.
Old Feb 20, 2012 | 01:56 PM
JS22's Avatar
JS22
yess, i read that post, thank you.
yet my question still remains regarding the diff size tires, correct pressure will be a diff volume in a bigger tire, will this have any effect on tpms
Old Feb 20, 2012 | 02:16 PM
PikesPeakZ's Avatar
PikesPeakZ
Could be a contributor depends. Read through this to see what relates to your symptoms.
https://my350z.com/forum/2003-2009-n...44#post3788619
If the light comes on about 30 minutes after driving randomly you have a bad sensor.
Old Feb 20, 2012 | 03:30 PM
DavesZ#3's Avatar
DavesZ#3
Volume has nothing to do with the sensors. They work on any size tire, air or nitrogen, etc.
Old Mar 7, 2012 | 03:56 PM
Deteria's Avatar
Deteria
What model # of TPMS do we usually get for 07+? Can I use this? http://www.ebay.com/itm/TPMS-OEM-Tyr...ht_3001wt_1396
40700-JA01B? Ones I got on my Z are blue and are the 40700-CD001.
Old Mar 7, 2012 | 05:56 PM
ronn1's Avatar
ronn1
Volume means nothing..they only measure the PRESSURE. Sure, a larger tire takes more air to reach a given pressure, but the sensor only *sees* the PRESSURE.
Stevo Z
Oct 3, 2015 09:14 PM
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
Alexreyes
Sep 30, 2015 11:30 PM
