Belts!
Old Mar 2, 2012 | 12:53 AM
tw8715's Avatar
tw8715
Default Belts!
I change my steering and ac belts but my steering feels like sometimes it's loosing it's power steering.
Did I tighten the belt too much?
I tighten the belts by hand feel
Old Mar 2, 2012 | 02:31 AM
JCITY's Avatar
JCITY
Question tightened to specs?
Did you tighten to specs?
Was the power steering ok before you changed the belts?
Are you SURE you installed the belts in the correct order?
Its good to draw a diagram when you remove the old belts.
Easy to screw this up if you are not familiar with the pattern.
Old Mar 2, 2012 | 04:22 AM
Bober'z's Avatar
Bober'z
check the belt diagram, you might of put it on wrong
Old Mar 2, 2012 | 11:56 AM
tw8715's Avatar
tw8715
The belts are on right. Steering was fine before.
Tight to spec not sure of. Just kind of tighten to feel
Old Mar 4, 2012 | 01:32 AM
tw8715's Avatar
tw8715
Is the belt slipping? Do I need to tighten more or loosen it up a little?
Help anyone
Old Mar 5, 2012 | 09:45 AM
tw8715's Avatar
tw8715
Bump
Old Mar 10, 2012 | 11:12 AM
bajamike's Avatar
bajamike
There is a good thread in the DIY forum about this.
Old Mar 10, 2012 | 12:44 PM
Bober'z's Avatar
Bober'z
you should check and retigthen, im almost positive the belt will stretch alittle right after being used for a couple minutes
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
