Coolant Refill Volume
Old Mar 9, 2012 | 10:11 AM
pilotstephen's Avatar
pilotstephen
Default Coolant Refill Volume
If you drain all the coolant from an 03 350z on level ground using the plug at the bottom of the radiator, how much coolant volume should you expect? I'm only getting about a gallon. I was reading that a complete fill should take about 2.5 gal (10 quarts) Is there 1.5 gallons that usually remains in the engine ?
Old Mar 9, 2012 | 10:24 AM
Bober'z's Avatar
Bober'z
Yes, 2.5 gal is when you drain the block also. Since your draining from the radiator, assuming your car isn't anywhere close to operating temperature, the thermostat is closed keeping the remain 1.5 gal in the block.
Old Mar 9, 2012 | 10:32 AM
You can fill and drain the coolant twice.
Run the motor with the heater ON.
That should get 80 percent of the old coolant out of the block.
Chris350z03
Oct 8, 2023 07:19 PM
m_0g
Jun 3, 2021 10:05 AM
SharX59
Sep 27, 2015 09:23 AM
smithmt3
Sep 11, 2015 08:25 PM
