No grinding just hard to shift into 6th
Old Apr 7, 2012 | 04:51 AM
Submariner's Avatar
Submariner
Default No grinding just hard to shift into 6th
Ok 1st I searched the board on 6th and hard shifting and no hits that match my issue(?).
Background - 07 ZR Grand Touring 6-sp with 13,400 miles.
1st thru 5th she shifts fine but 5th to 6th at times it just won't go into gear. It's almost as if there is no 6th gear and more than once I've ended up going into 4th instead. While at a stop I can go thru all gears just fine. This issue can happen from 55 on up to 80. Like I said there is no grinding it is just at times impossible to get her into 6th gear. After a few tries she finally will drop in.
Any insight? Monday I'm headed to the dealer while it is still under the 3 month 3,000 mile warrenty.
Old Apr 7, 2012 | 05:39 AM
baker0308's Avatar
baker0308
all u have to do is remove the shift boot and there will be three 10mm bolts, loosen them and readjust ur reverse lockout plate... need pics?
Old Apr 7, 2012 | 05:49 AM
Submariner's Avatar
Submariner
Please if it isn't to much to ask.
Old Apr 7, 2012 | 07:43 AM
Submariner's Avatar
Submariner
No longer any need on the pics Baker0308. did a search on reverse lockout and found pics in the directions on how to install a short shifter. Thanks for the offer.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
