ECU simulator
Old Apr 8, 2012 | 05:12 PM
imkindafkedup's Avatar
imkindafkedup
Default ECU simulator
This maybe a long shot but has anyone heard of or used a product like this?
Product Information
The CAN BUS 11/29 ID , 250/500kB Multiple ECU simulator is a best suited tool for the development and testing of OBDII diagnostic programs and hardware. It simulates Engine ECU , TCM ECU and ABS ECU simultanously. More than 3 DTC are generated and sent in multiple frames. Reading suspended DTC and VIN is also possible. It has 5 user-adjustable and several fixed-value PIDs for each ECU. The DTC button can be used to generate trouble codes and illuminate the MIL LED. The trouble codes can be cleared using a Service 4 request . Physical connection is made through a standard SAE J1962 connector. This item needs a external 12V power supply . For more info about schematic or implemented PID please refer to the datasheet oe91c1610 in the support/datasheet section.
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
