start problem please help me
Old Apr 29, 2012 | 12:19 PM
Abdulrhman Khal's Avatar
Abdulrhman Khal
Unhappy start problem please help me
hi guys my car is 2003 touring 6mt
i blow the engine then i bought 2005 5at engine only
when i replace the engine too many problems started
cam codes, crank code
the car takes time to start and the rpm needle not vary accurate jumps up and
down i took my friend sensors and replace them to check
i replace the sensors and cleared the codes and drove it for 200 miles
the lights came up and the codes came up too.
i have taken the car to 5 shops here is what they:
1- he said all my sensors are ok and my harness ok the problem from bcm
the bcm saves the codes and throw them again.
2- he said that my fuel pump weak and the injectors are weak too.
3- he said the harness is shorted somewhere or the ecu is broken.
4- he said the flywheel is not properly balanced or missing a tooth and the timing chain not balanced.
5- i had to travel to kuwait which is 300 miles away from my home and back at the same day, he said that the upper oil pan is different because my car is 6mt and the new engine is 2005 auto trans so the sensor sites farther in the auto trans engine.
here is a utube vid for starting the car
http://www.youtube.com/watch?v=MviWS...ature=youtu.be
please please please guys help me im so desperate i hate my dream car
because of this problem
best regards
abdulrahman from Saudi Arabia
Old Apr 30, 2012 | 11:07 AM
Abdulrhman Khal
anybody
Old May 1, 2012 | 07:12 PM
Itzcashew's Avatar
Itzcashew
Did you keep the 6mt or put the 5at in? You might have the wrong ecu hooked up.
Old May 2, 2012 | 09:57 AM
Abdulrhman Khal
i kept the 6mt
Old May 2, 2012 | 03:33 PM
Itzcashew's Avatar
Itzcashew
And did you kept the same ECU ?
Old May 8, 2012 | 11:57 AM
Abdulrhman Khal
yes i kept the same ecu
Uriyo_
Sep 8, 2021 08:46 AM
