car won't blow hot air when idling
Old Jun 2, 2012 | 06:34 PM
black3.5z's Avatar
black3.5z
Default car won't blow hot air when idling
like the title says if the heat is set to 90 it will blow hot air from the vents find but soon as i stop at a light and the engine drops down to idle rpms it goes cold. Then when i start moving again it gets hot again any ideas i checked my coolant its not low im baffled.
Old Jun 2, 2012 | 08:30 PM
Lee R's Avatar
Lee R
It could happen if you get air into the heater core. Did you flush your system lately? Burp it?
Raise the front of the car and run it for like 10 minutes. Lower it back down and see if you need to add more water. You'd be surprised how much better your heater would work after this.....if that was the problem.
Old Jun 2, 2012 | 08:33 PM
RMichael's Avatar
RMichael
Originally Posted by Lee R
heater core.
Old Jun 2, 2012 | 09:49 PM
bbs350z's Avatar
bbs350z
try bleeding your coolnt system. if not, most likely your core. good luck, its a ***** to rip out.
Old Jun 3, 2012 | 06:45 AM
black3.5z's Avatar
black3.5z
oh gees i don't like the sound of that. i was actually going to get my system flushed. thanks guys
Old Jun 3, 2012 | 07:22 AM
Patrick250's Avatar
Patrick250
You probably have air trapped in the cooling system. It has been discussed here before.
Similar thread:
https://my350z.com/forum/maintenance...in-motion.html
There's an air relief plug on one of the heater hoses in the engine bay.
DE air bleed on passenger side.
The HR air bleed is on the driver side under the upper right corner of the engine cover.
DE FSM: http://www.nicoclub.com/FSM/350Z/coupe/2005/co.pdf
HR FSM: http://www.nicoclub.com/FSM/350Z/cou...oadster/CO.pdf
Old Jun 3, 2012 | 10:48 AM
black3.5z's Avatar
black3.5z
Wow thanks I will have to give that a try the car is a 04.5 with 53000 miles I didn't figure the heater core was gone. But weirder things have happened.
How do you use that let the car idle up to temp then crack it a little
Old Jun 3, 2012 | 10:53 AM
Cass007's Avatar
Cass007
Yes, or you can get the spilless funnel for the radiator cap. Pinch the coolant hoses off and on a bit as well. Finally, check to make sure the overflow container has not run dry and is at the proper level.
Old Jun 3, 2012 | 10:56 AM
black3.5z's Avatar
black3.5z
Sounds good I will give it a try
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
