Quick Leak Help
Old Jun 6, 2012 | 03:16 PM
DCJodon's Avatar
DCJodon
Default Quick Leak Help
I need just a quick rundown of what this leak is, what the defective part could be, and how immediately concerned should I be. Thanks.
Old Jun 6, 2012 | 04:03 PM
zeroaccessinc's Avatar
zeroaccessinc
Isn't that your fuel line?
Old Jun 6, 2012 | 04:21 PM
SxExCx's Avatar
SxExCx
It is either fuel or brakes...both are kinda important.
Old Jun 6, 2012 | 04:41 PM
If you touch the wet area cant you tell what the fluid is by the feel and odor?
Old Jun 6, 2012 | 05:02 PM
DCJodon's Avatar
DCJodon
That was my first test, it really doesn't have a fuel-like smell at all, but the liquid leaks clear. It looks like the middle line is the culprit.
EDIT: Drove it around for a bit, to see if I can increase the leak to see where it's actually coming from. It's coming from above these lines, through the hole at the top. It hits the lines, making it look like they're leaking. Clear liquid, seems like water, but it still seems to leak on dry days. I put a cup under the leak, will let it sit overnight to see what/how much it is.
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
