Engine broke! What should I do?
Old Jun 14, 2012 | 11:32 AM
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
Originally Posted by BigZeus
Replace the engine, its worth it. I just replaced mine with an engine with 60k on it. 2300 for the engine + install. If i were you I'd replace the engine first then sell because nobody's going to pay good money for a 350z with a POS engine. And if you do replace the engine make sure to run the VIN to see if it has the correct amount of miles!
Those are good points too.
Old Jun 14, 2012 | 11:33 AM
nbdyfcnsqnc
Originally Posted by drivessidewayz
I'm in the ls/lq swap boat. Most likely lq because from what I've read on ls forums they're more durable; the car weighs so damn much to begin with the extra 80-ish lbs won't be noticed if you shift the battery. To answer your weight difference question between the vq and ls, the ls weighs about the same or slightly less based on one or two threads on our forums. I don't have links atm.
Thanks for the info.
I could probably lose 40lbs myself to offset some of that too
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
