Driver Door Issues
Old Aug 8, 2012 | 09:43 AM
FlamZ's Avatar
FlamZ
Thumbs down Driver Door Issues
Recently my driver door sensor stopped recognizing that my door is closed and will not automatically roll up my window to seal it. Anyone else have to deal with this issue ever? Its showing that my door is ajar even when it is closed and the window can't seal without the sensor working properly.
Old Aug 8, 2012 | 09:59 AM
terrasmak's Avatar
Not a sensor, just a door switch mounted on the body at the back of the door.
Old Aug 8, 2012 | 10:02 AM
Syner's Avatar
Syner
Yea, it's just a little button. It's covered with some black rubber. It probably got stuck, you can feel if it is just by pushing on the button with your fingers.
Old Aug 8, 2012 | 10:11 AM
FlamZ's Avatar
FlamZ
The button doesnt seem to be stuck though i already checked that out
Old Aug 8, 2012 | 10:38 AM
Syner's Avatar
Syner
Doesn't seem to be stuck or it isn't stuck? You should be able to tell very easily.
Old Aug 8, 2012 | 11:39 AM
PerfZ's Avatar
PerfZ
If you manually push the button and the door-ajar light goes out, then it works. If it stays on, then it doesn't.
Old Aug 8, 2012 | 01:20 PM
IDrm350's Avatar
IDrm350
Does your dome light stay on too?
Old Aug 8, 2012 | 02:23 PM
FlamZ's Avatar
FlamZ
it doesnt work, i have the dome set not to come on when i open my doors but im guessing it will just stay on too
Old Aug 8, 2012 | 02:24 PM
FlamZ's Avatar
FlamZ
the button works fine but nothing happens when its pushed all the way in, the car still thinks the doors open
Old Aug 8, 2012 | 02:42 PM
RandyK1's Avatar
RandyK1
Unscrew the door switch, unplug the two wires, turn on your key, touch both wires together and see if the light goes out. If it does then you have a bad door switch, if not then something else is wrong.
Old Aug 8, 2012 | 08:12 PM
albinobob's Avatar
albinobob
In my '04 it's just one wire and it gets ground out to the screw holding it in place. You can switch out the driver and passenger side and if the problem moves it's the switch. Otherwise you got a short to ground somewhere.
Wire grounded = Door Open
Old Aug 9, 2012 | 07:42 AM
Syner's Avatar
Syner
Old Aug 9, 2012 | 02:14 PM
PerfZ's Avatar
PerfZ
Button - fine. Switch - bad. I guess it's semantics.....
Replace the switch/button whatever you want to call it.
sherm
Apr 11, 2020 05:21 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
