Trouble Code P0304 on 350Z
Old Aug 9, 2012 | 09:18 AM
Elcidious's Avatar
Elcidious
Default Trouble Code P0304 on 350Z
I have a 2003 350z that I bought 2 months ago and I have placed a new Injen CAI on it. After installing it I have had a trouble code come up P0304 and I have cleared it only to have it come back after 200-300 miles. I have replaced the spark plugs, moved all the coils to different cylenders (to see if that was a bad coli and code came back the same) added fuel injector cleaner also. Could it be a vacuum leak?
Thanks in advance...
Old Aug 9, 2012 | 09:41 AM
Neimad's Avatar
Neimad
Check the PCV breather hose but that's closer to cyl 6 so I doubt vacuum leak. Check wiring harness, do compression test.
Old Aug 9, 2012 | 09:48 AM
Elcidious's Avatar
Elcidious
Thanks for the advice.. Ill check the PCV hose tonight along with the wiring harness....
Old Aug 9, 2012 | 07:19 PM
GGGVenom's Avatar
GGGVenom
P0304 is a generic code for misfire on cylinder 4; did you see oil on top of the plug when you removed it .. possible short in wiring if you have already moved the coils around ..
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
pslamp32
Feb 8, 2017 09:07 AM
350Z Project X
Oct 17, 2015 05:16 PM
RyansZ33
Sep 15, 2015 05:54 AM
