Error Code HELP!!
Old Aug 22, 2012 | 02:24 PM
jrzhoe24's Avatar
jrzhoe24
Exclamation Error Code HELP!!
hey everyone i know there are one or two other threads involving my problem but none seem to reallygive me a good understanding so here goes nothing (yes i realize im somewhat of a tech noob)..
my service engine soon light recently came on. Around the beginning of the summer i switched to turbo xs non resonated test pipes.. hooked up/installed .. no problems, no lights.. about a week later i switched from my pop charger to the full k&n typhoon system.. the filter was dirty so i cleaned it with the proper kit n procedure.. about an hour or two later the service light came on.. before checking the code i re-cleaned and reoiled the filter as well as checked the new tps.. i notice a bolt was loose on the drivers side causing a minor exhuast leak witch i immediately fixed..
ok now that thats been said heres my error readings.. there were 2 readings but they were both the same.. p1273 air fuel sensor 1 heater band... im wondering if it was cuased from the exhaust leak and i just need to reset the ecu but why would it come up as both (2) errors.. thanks in advance i know its not the easiest question to understand but ireally appreciate everyone who helps me out on here..
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
