ABS Code C1111, HELP!
Old Sep 4, 2012 | 07:09 PM
ZDominicZ's Avatar
ZDominicZ
Default ABS Code C1111, HELP!
hi, I just brought my 2003 350z to a mechanic because of an abs light that has been going off and on. By that I mean everyother or so startup the abs light turns on and stays on. The mechanic pulled the code C1111, which means abs power relay coil open circuit.
He said that the only fix would be to replace the abs module ($1000+)! Is there anything you guys can think of to avoid this?, And is the module definitely whats wrong? Any help would be appreciated greatly!
Old Aug 2, 2014 | 09:21 AM
Speednz's Avatar
Speednz
Same code on mine, did you ever get this solved?
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
