Lost Bleeder Screw for Coolant
Old Sep 11, 2012 | 11:39 AM
RedBullRR's Avatar
RedBullRR
Default Coolant Leak
I've searched high and low, anyone know were I can pick one up. Or can setup a different one that isnt plastic? Car is currently stuck because of the FN Dealership topping off antifreeze then not bleeding system.
Last edited by RedBullRR; Sep 18, 2012 at 11:17 AM. Reason: Original title is invalid
Old Sep 11, 2012 | 12:27 PM
Junkster's Avatar
Junkster
check car-par.com and call around, pretty sure you can find a junk yard that will be willing to sell you one for cheap.
other than that, call a dealership and have them order it
Old Sep 11, 2012 | 12:33 PM
Junkster's Avatar
Junkster
car part i mean
Old Sep 11, 2012 | 01:11 PM
ImWeeZzel's Avatar
ImWeeZzel
i fawked mine up bleeding my coolant last year, contact concept z performance, have them send you a new one. problem fixed/thread
Old Sep 11, 2012 | 01:39 PM
patrickoneal's Avatar
patrickoneal
Is it 21440-5V000?
http://www.conceptzperformance.com/C...166.249.68.230
If you need it right away, call your closest Nissan or Infiniti dealer to check pricing and availability. They won't often volunteer it, but with a couple of keystrokes they can check stock at all the dealers in the area. This will save you from calling 10 different places to check stock.
Old Sep 12, 2012 | 09:08 AM
RedBullRR's Avatar
RedBullRR
Found it, its destroyed but still works. Was able to resolve this last night. I mean I gotta be honest this car is the most difficult there is when it comes to bleeding the antifreeze. It's never perfect. I never really get hot hot air when car is idle.
Old Sep 12, 2012 | 09:33 AM
ImWeeZzel's Avatar
ImWeeZzel
Look up coolant purge nightmare
Old Sep 18, 2012 | 07:55 AM
RedBullRR's Avatar
RedBullRR
Originally Posted by patrickoneal
Is it 21440-5V000?
This is the drain **** for the radiator, and is not the same as the Bleeder Screw. The Drain **** does not screw in vs the bleeder screw from what I can tell. Anyone else know where I can easily pick one up. Mines is destroyed.
Old Sep 18, 2012 | 09:35 AM
ImWeeZzel's Avatar
ImWeeZzel
Call conceptzperformance and ask for Mike or Coz. They've both very good at what they do...
Old Sep 18, 2012 | 11:03 AM
RedBullRR's Avatar
RedBullRR
Do you guys think I have a bad radiator? Seems like fluid keeps coming out of the edge of the radiator. I checked hose I dont feel moisture on it.
Old Sep 18, 2012 | 11:48 AM
SLOPOS's Avatar
SLOPOS
Hehe....he said **** plug....
Old Sep 18, 2012 | 12:10 PM
ImWeeZzel's Avatar
ImWeeZzel
get a pressure test done on your radiator son... the oem radiators are week sauce and teh plastic cracks. usually a common thing on most vehicles brah'
om nom nom nom
or ghett0 but effcient:
RedBullRR's Avatar
RedBullRR
I did I did. LOL
Old Sep 18, 2012 | 12:49 PM
RedBullRR's Avatar
RedBullRR
Okay, I am guessing I need a new radiator. This blows donkey *****. LOL Anyone know a decent price for one?
Old Sep 18, 2012 | 04:29 PM
Glex25's Avatar
Glex25
You can find a OE replacement radiator for less than $100
or you can upgrade to something like a Koyo
Old Sep 19, 2012 | 12:25 PM
RedBullRR's Avatar
RedBullRR
Hey Glex25, you know any place off the top of your head were I can pick one up for that price? Anyone think I can get by using a radiator sealant?
Old Sep 19, 2012 | 01:15 PM
patrickoneal
rockauto.com
You could try bar's leak stopper. I've had luck with it in the past if it's a slow leak. A radiator repair shop might also be able to fix it if you pull it out and bring it to them.
Old Sep 19, 2012 | 02:22 PM
Glex25's Avatar
Glex25
I google 350z Radiator OE and found tons on result for less than a $100 shipped
I also found the part numbers for the bleeder screw for you
21440-5V000 ****-Water Control
21481-89900 Packing
92500-AR000 Connector-Heater Hose
The drain plug and seal for the radiator keeps coming up as the same number for the bleeder screw and seal
Old Sep 20, 2012 | 06:12 AM
RedBullRR's Avatar
RedBullRR
Thinking about purchasing a Dual Core Aluminum Radiator from Ebay. Friend said he had a lot of luck with this on his Z, and Silvia. Thoughts?
http://www.ebay.com/itm/DUAL-CORE-AL...b&vxp=mtr#shId
Old Sep 20, 2012 | 07:38 AM
Glex25's Avatar
Glex25
Their description of which car it fits makes no sense G35/350Z have different mount position plus there is a difference between automatic and 6MT radiators.
They also list it fitting G35/350z 2003-2009 which makes no sense since they all have different motor V35DE/VQ35HR/VQ37HR. I wouldn't if you want a double row go with Koyo or any other known name brand.
