4th rough shifting into
I have an 06 6mt and I replaced the clutch and flywheel about 1100 miles ago. Ever since then its hard to quick shift into 4th gear when getting into it. Granny shifting its just fine. All the other gears are fine. Any suggestions?
Well before the clutch install. I could shift a lot quicker when racing or just during spirited driving. Just to be clear, I'm not talking about going all the way to red line in 3rd. I just mean when I'm at WOT and I go to quick shift into 4th if I hurry to shift then it doesn't go in. And I guess I just noticed that when im shifting into all the other gears aren't quite as smooth even when I'm just cruising after the clutch install. With a light flywheel and stronger pressure, do you generally have to slow down your shifting? Or is there something I should try adjusting? Such as the clutch pedal or shifter itself. Any input would be greatly appreciated.
04-04-2016 07:52 AM
