Clutch/transmission issues? Please help.
Old Oct 21, 2012 | 08:09 PM
EugeneC7152's Avatar
EugeneC7152
Default Clutch/transmission issues? Please help.
I floored my car in first and then in second gear with traction control off. Very shortly after the car was difficult to shift into the gears. I basically had to revmatch my car all the rest of the way to work. When I went home I had to give the clutch pedal full travel just to help work the transmission a little.
Does this mean my clutch went bad? I still have pedal feel but now my clutch hardly wants to disengage. I feel like it's always partially engaged because the car move as little when I start it in 1st.
If I floor it in say 3rd 4th or 5th gear and the clutch doesn't slip does that mean it's okay and most likely something else?
I need to check the master cylinder and slave cylinder to make sure there isn't any leaking but the reservoir is still full.
Btw I have a RPS clutch/flywheel setup
Old Oct 22, 2012 | 05:09 PM
bmyles's Avatar
bmyles
What year? If you have an '03/'04, the clutch fork is weak and will flex under a heavier pressure plate. Could be master/slave problem, but if it's not, could be a pressure plate issue.
Old Oct 23, 2012 | 12:02 AM
Everybodywildou's Avatar
Everybodywildou
Yeah it's an 04. I was thinking it would be the clutch for too. I guess I'll be taking it apart soon. Crap. Lol
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
